LQ4 with VVT?
Old Feb 10, 2015 | 07:20 PM
Jasoncapps71's Avatar
Default LQ4 with VVT?
I have an LQ4 that has been punched out 40 over flat tops and it has a 58 tooth reluctor wheel. I have a set of 318 heads that I have not installed yet. I am going to install this engine into my 2000 Silverado. My question is, can I install a VVT cam? If no, why? If yes, what else do I need. I am a little worried about valve to piston clearance and I still need to get a PCM and wiring harness.
Old Feb 11, 2015 | 03:44 AM
Jimbo1367's Avatar
yes you can use a VVT cam. Use the VVT timing cover from your old engine and oil pan. Everything should swap over. Patrick G. can spec you a custom VVT cam.
Old Feb 11, 2015 | 05:06 AM
jimmyg's Avatar
Mast motorsports has vvt cams. With ecm/harness tuned for their cams
