lt1 t56 to ls different conversion option
Or is the gap way too much? Just figure guys run old style 4spds behind ls engines without too much trouble so there must be a way.
Thanks in advance!
Flywheel spacers are bad for starter engagement. Even 0.100"
It's just like a 4 speed swap, it isn't rocket surgery. LS3 pilot bearing (larger sealed bearing that goes into the first register of the crank) for 4 speeds, TKOs, Richmond 5/6s, LT1 T56s, and later TR6060s, 4th gen camaro/traditional small block chevy pilot bearing or bushing for the longer LS1 input t56.
I'm not sure where the need to space the flywheel is coming from, the clutch should still be able to ride fine on the input shaft as the additional length is past the clutch disc, it might ride in a different spot on the input shaft than the LT1 clutch did but that's not the end of the world.
What's wring with the pull style clutch? An honest question.
https://ls1tech.com/forums/lt1-lt4-m...ear-ratio.html
http://www.thirdgen.org/forums/trans...-1993-t56.html
Realistically, I don't see why you could not just take the 5-6 gears from a 93 box and put them in a 94+ for a closer ratio transmission. It'd have to be the 5-6 pair to work though.
Here is the link :
https://ls1tech.com/forums/conversio...-ls-motor.html
