Installing LS2 in 1968 Chevelle Next Week
So I have this fairly bare LS2 sitting in the engine bay and I have all the accessories. What I don't have or know is all the mandatory and required hose connections that need to be made in the intake area.
I have a FAST intake that has a fitting at the rear (brake vacuum I believe...which I don't have power brakes, so I'll plug that right?). Then there are two ports at the front, one on either side of the intake. Where do those connect to?
And where does the fitting from the front of the base plate underneath the intake connect to? And where is the PCV valve on this engine?
What is fitting for on the passenger forward valve cover for? (mine has a little filter on it)
What is the fitting for on the driver side rear valve cover for? (mine appears to be capped)
Sorry for the silly questions, they are just now coming to me.
Aft part of intake
Front part of intake, ports on both side.
Front of passenger side valve cover.
Aft of driver side valve cover
What steam port setup is that?
Do I just put vacuum caps on the rear port and the front driver side port?
This LS2 does not have a PCV valve does it? If it does...where is it located?
