Ly6 wiring questions
Old Feb 21, 2015 | 04:58 PM
jimmyg's Avatar
Default Ly6 wiring questions
ok I have 2010 ly6 with ls3 intake .mast harness came with wrong plugs for oil pressure and map sensor. Question can I take plugs off factory harness and solder on to mast harness? Each plug has 3 wires if I solder wires on in same sequence will it work? Or do I need pin out? Mast plugs seem to be for earlier ly6. Map sensor plug looks like ls1 any help is apprec thanks
Old Feb 22, 2015 | 06:44 AM
casias's Avatar
If you bought a Mast harness with the wrong plugs, I would contact them.
Old Feb 23, 2015 | 06:32 PM
jimmyg's Avatar
Ok got it straightened out I need a 08 ly6 oil pressure sender and they are sending me the right harness for map sensor. Most ly6 have smaller oil sender but they changed in 2010 to larger one
