DBW harness vs. DBC harness
Old Feb 25, 2015 | 08:19 PM
popsawheelie's Avatar
Default DBW harness vs. DBC harness
I have a DBW harness that I'll be using for my swap, however I and going to use a cable drive throttle body. Will the DBW harness work and/or how will I have to modify it?
Old Feb 25, 2015 | 08:49 PM
LLLosingit's Avatar
Right off the top of my head your dbw harness won't have a IAC connector. Other than that I don't have a clue.
Old Feb 26, 2015 | 12:24 AM
98TA6.0's Avatar
Depends on what you're doing with it. I never use stock configuration harnesses bc they are all crusty and ugly. If you strip it down you will need to repin the connector and add some pigtails. Pretty easy
Old Feb 26, 2015 | 03:23 AM
ls1nova71's Avatar
You didnt say what year the engine/harness is. If it's a genIV, then it will be a lot harder. An older genIII is pretty a simple matter of adding the IAC and TPS connectors in place of the DBW plug. Also know that some PCMs dont have IAC drivers in them , so you will need to make sure yours does.
Old Feb 26, 2015 | 09:14 AM
Pony Exp.305's Avatar
Good to know..
Old Feb 27, 2015 | 12:53 AM
G-Body's Avatar
sawzall wielding director
Which PCM are you going to run? It may be easier to just pick up a new harness/pcm already set up for cable TB. Only some of the newer green/blue PCM`s can run a cable TB and although you can convert a harness from a green/blue to a red/blue PCM its not really worth the time.
Old Feb 27, 2015 | 06:13 AM
lsxRanger94's Avatar
Read this. I used it to convert my 05 harness to dbc.
http://www.lt1swap.com/cable_conversion.htm
