First Startup: P2138 and no throttle
Old Mar 12, 2015 | 11:02 AM
leblanc1's Avatar
I got the ECM back last night with the same exact results. No Bueno.
Old Mar 24, 2015 | 11:02 PM
leblanc1's Avatar
Sorry for the delay....I just got my ECM back yesterday from Bill at BP Automotive. All is fixed and good to go. He ended up loading a Corvette OS onto the ECM and had me change some pinouts on my pedal connector and all is perfect and rock n roll. No codes and beautiful throttle response. She sounds way mean.
Old Jul 31, 2019 | 10:29 AM
dantonioauto's Avatar
Originally Posted by onebadbowtie86
Im having similar issues with my ls2 swap from a gto using stock ecm/tb/pedal. the car will start and idle but the throttle is almost in a limp mode, very little happens when you mash the pedal. If you pump the gas once right when the engine starts, it seems to work almost how it supposed to?
I am having the identical issue with an 06 GTO LS2/T56 swap. Did you ever come up with a fix? I am stumpped.
Old Aug 2, 2019 | 09:54 PM
john morse's Avatar
Default App wire change
I had to swap APP wires D and F. I had correct vortec pedal for vortec motor but ecm was wired for camaro. Only diff is to swap D and F. Problem instantly solved.
