Harness & Gauge question
Old Feb 26, 2015 | 07:06 AM
KilrMGBGT's Avatar
Default Harness & Gauge question
Sorry if this has been asked before but I could not find what I was after in a search
I am making my own harness with help from the forum and lt1swap
What I can't figure out is how to incorporate my aftermarket gauges
Speedo, tach, alt, temps & pressure
do these come out of the pcm or do I need extra senders for all
Any help would be appreciated
Old Feb 26, 2015 | 08:26 AM
1964SS's Avatar
What vehicle and gauges? What type of PCM are you using?
Old Feb 26, 2015 | 09:16 AM
KilrMGBGT's Avatar
It's a 1968 MGB GT
Vette LS1 w/ 02 Camaro pcm
Will be using Autometer gauges
Old Feb 26, 2015 | 11:22 AM
1964SS's Avatar
Speedo will run off PCM as long you have the VSS on the trans hooked up. Tach runs off the PCM as well. Temp and oil pressure need sending units. Voltage gauge simply hooks up to switched ignition.
Old Feb 26, 2015 | 02:52 PM
KilrMGBGT's Avatar
Thanks for the help
Does the pcm need an oil pressure sender or can I use it for the gauge? I know I can add the second sender to the other head for the temp
Old Feb 26, 2015 | 03:24 PM
gofastwclass's Avatar
The PCM does not need to know the oil pressure. The oil sending unit on the harness goes directly to an idiot light or a gauge in the dash depending on model with that PCM.
Old Feb 26, 2015 | 07:34 PM
KilrMGBGT's Avatar
Thanks for all the help!!!
