G body swap ?s
Old Mar 1, 2015 | 11:35 AM
SPOOLIN Z28's Avatar
Default G body swap ?s
Starting on a g body that is going to be getting a 6.0 with a mild cam. It will not have ac and I'm looking for other accesories bracket options other than the massive truck bracket. I do plan on running a car intake manifold. Any help is appreciated.
Old Mar 1, 2015 | 11:52 AM
user 4737373's Avatar
Your options depend on three primary factors, which are: 1.) Are you going to run the stock A/C box.? 2.) What steering box are you going to use? 3.) What engine mounting brackets are you going to use?
Old Mar 1, 2015 | 01:24 PM
No ac or ac box, it will have power steering and stock gear box and using some mounts from jegs
Old Mar 1, 2015 | 01:38 PM
Do you have the 605 box that was used on the majority of G-body cars, or the quick ratio 700 series box that was used on the performance model G-bodies (Monte Carlo SS, Grand National). What set-back are your swap plates advertised to have?
Old Mar 1, 2015 | 02:54 PM
Fry_'s Avatar
Do yourself a favor and just return any parts you've already bought and buy all of the Hooker/ Holley g body swap parts. You'll save time, headaches and have a cleaner and better engineered swap when finished.
https://ls1tech.com/forums/conversio...m-preview.html
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 1, 2015 | 03:57 PM
jimmyg's Avatar
Sound advice.
Old Mar 1, 2015 | 04:56 PM
jmd's Avatar
jmd
How far inboard is the exhaust hump in their crossmember?
I like how they addressed the 200-4R crossmember frame extension in the PDFs.
Old Mar 1, 2015 | 05:18 PM
To Fry/jimmyg...thanks for the plugs guys, it has much more value coming from users such as yourself than from someone directly affiliated with Hooker/Holley.
