BMW electric heater control valve
Old Mar 6, 2015 | 01:17 PM
apiazza2010's Avatar
Default BMW electric heater control valve
I have an ls1 swapped e30 and would like to put back the heater core in line with the cooling, I believe my car has a NON bypass heater control valve that is electrical.
What do you guys that did swap on BMW's use for a bypass 4 way heater control valve that is electrical?
I have read that I need a bypass one to keep flow on the heater loop for the thermostat?
Any advice is appreciated.
Thanks
Old Mar 6, 2015 | 01:57 PM
I was thinking on using a the common Dorman 74781 ranger 4 way bypass valve and then using the cheapest vaccum solenoid I found at Napa 219226, I would then connect the solenoid to the same wire the e30 heater control valve is connected and have them in series as I don't want to damage the heater core trying to remove the old one
Old Mar 6, 2015 | 01:58 PM
garys 68's Avatar
I'm running 2 LS swaps with aftermarket AC systems (Vintage ans Classic) and non bypass HCVs, no issues.
There are electric 4 port bypass HCV though. Check ebay for a Lincoln LS heater control valve. Not sure if it's normally open or closed.
Old Mar 6, 2015 | 04:48 PM
ls1nova71's Avatar
Same here, I have two swaps with Vintage Air and never seen a problem with either one.
