Best way to clean the inside of the engine?
Old Mar 10, 2015 | 01:16 PM
martsink's Avatar
Default Best way to clean the inside of the engine?
I would like to clean up my engine as much as possible before assembly just to make sure there's no dirty trapped anywhere. Most of the engine components are still on, the only the heads and the oil pan are off. Should I just reassemble it and flush the oil and coolant a few times?
Old Mar 10, 2015 | 05:02 PM
Cyrus Johnson's Avatar
Used, rebuilding or new?
If used just install engine on engine stand and use cleaner with bristle brush.
If rebuilding the parts should have been cleaned before you start putting it together.
If new then cleaning with paint thinner should work.
If you try to clean by running the engine then you are too late and time to rebuild, again.
Old Mar 10, 2015 | 05:56 PM
martsink's Avatar
Thanks! Its used, but I had to take the heads and oil pan off for my project.
