VVT harness to non-VVT engine?
Old Mar 14, 2015 | 11:11 PM
ErikSOCAL's Avatar
Default VVT harness to non-VVT engine?
Have what I believe is a GENIV 5.3 non VVT motor. Just getting around to installing a harness which is not original to the motor. Looks like the harness has a VVT cam sensor plug and the cam sensor connector on engine is a non VVT. Is there an easy (and hopefully inexpensive) fix for this?
Harness connector
Engine
Similar with VSS. Positive the trans was built well before the vehicle for the donor harness. Is there an easy (and hopefully inexpensive) way to fix this?
harness
trans
thank you
Old Mar 16, 2015 | 07:13 PM
ErikSOCAL's Avatar
TTT updated the title for better help
Old Mar 16, 2015 | 07:16 PM
1989GTA's Avatar
When I bought my VVT delete kit there was an adaptor harness included. So I know there is one available, I just don't know where you can buy that part alone.
Old Mar 16, 2015 | 08:40 PM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
We make the adapter harness you need. Just shoot us an email at the email in our signature and we will send you a link to the item on our site. It's $22. Hope this helps!
As for the VSS it is on the tail shaft. You pictured one of the solenoids.
Bill
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Mar 16, 2015 | 09:23 PM
ErikSOCAL's Avatar
Bill and GTA, Thank you both for averting panic!
Bill, email inbound. Thanks for the extra tip on the VSS, time to cram my big noggin under the car again. Definitely need it up higher to find this thing.
