Ls1 swap
Old Mar 15, 2015 | 12:44 PM
1997's Avatar
Default Ls1 swap
I was looking to get some advice on a swap I have a 1996 Chevy k1500 and wanted to put a ls1 into in it. what are somethings that I would need. Thanks
Old Mar 15, 2015 | 12:56 PM
96capricemgr's Avatar
The true LS1 is about the last LS variant I would consider.
Old Mar 15, 2015 | 03:55 PM
Envy's Avatar
This was just asked about a week ago, you couldn't possibly have looked very hard.
96' is an early year, the 4l60e went through some minor changes, you might be better off with a full drivetrain swap engine/trans. In order to keep your existing mounting points, cross every and axles, you'll need mounts that are either adjustable to setback 1", and for AC, you'll need to notch your frame, or buy a relocation bracket. If you have a vortec, you should be able to use that fuel pump, but if it was a tbi you'll need a high pressure pump, plus depending on your LS, a fuel pressure regulator. You'll need a PCM to run the LS, and at a bare minimum, the anti-theft removed. You'll also need a harness to marry everything together. If it's a vortec truck you can modify existing harness to work, but most of the time it's easier to build a standalone and drop it all in. Good luck... and search!
http://bit.ly/1Lg2N24
Old Mar 15, 2015 | 08:53 PM
1997's Avatar
Envy thanks, I look for a little while but I couldn't find anything I guess I didn't look in the right spot
