DBW Throttle Body to DBC TB
Old Mar 16, 2015 | 02:23 AM
SweetNova's Avatar
Question DBW Throttle Body to DBC TB
I going to swap over to DBC. The 5.3 engine came with a DBW TB, what hardware/parts are needed to run the cable setup?.. besides the DBC TB
Old Mar 16, 2015 | 02:52 AM
lm38330's Avatar
When I bought an LS6 from a CTS-V, I changed over from DBW to DBC. I had to get rid of my harness and PCM which was a Blue/Green connector PCM/harness and switch to a Red/Blue harness and PCM.
The Red/Blue set up was ready to go for a DBC and all I needed was a throttle cable. I did this because I never bought my donor engine with matching pedal and TAC module.
Old Mar 16, 2015 | 05:50 AM
garys 68's Avatar
What year is the motor/ecu?
Up to 02 is easy. 03-06 may be possible, 07+ not practical.
Check out LT1swap for details.
Old Mar 19, 2015 | 10:22 AM
SweetNova's Avatar
The motor is a 2002 LM7 out of an avalanche. I'll be using the holley dominator setup.
Old Mar 19, 2015 | 10:47 AM
garys 68's Avatar
If the dominator is set up for cable tb and your using the holley harness, then all you'll need is a 3 bolt cable tb, TPS, and IAC.
