dayco 71132 ???
Old Mar 18, 2015 | 12:52 PM
Footbraker67's Avatar
Default dayco 71132 ???
Does anyone know if the Dayco 71132 upper radiator hose will fit an A-body with factory radiator and a TRUCK water pump?? I see alot of people using this hose but it seems like they all run the LS1 water pump. Thanks
Old Mar 18, 2015 | 01:14 PM
1964SS's Avatar
Just by looking at the hose I would say no it will not work on a truck water pump. Output is off the top of a truck pump which this hose does not have the bends for.
I've found that the easiest way to get a working hose is to take a few measurements and ask to go behind the counter of your local parts store and look at all the hoses yourself.
Old Mar 18, 2015 | 04:39 PM
76larkman's Avatar
check out a upper hose for a 2005 chevy ssr with 6.0. Thats what worked for me on my 76 skylark but I used ls camaro radiator/truck pump. you can find it on ebay gates 23027 is the number of it. It has a 90 at radiator end and couple angles at pump.
