Drive by Wire or Cable
Old Mar 18, 2015 | 07:48 PM
Black89Z51's Avatar
Default Drive by Wire or Cable
So I picked up a 2003 Tahoe from a salvage website and am looking to put the engine in an 85 T-bird. The truck is drive by wire, but for conversion and simplicity's sake, how difficult is it to throw on a cable TB and a TPS and ditch the accelerator pedal and the electronic TB?
I will be purchasing HP Tuners, so I'll have software if that's all it will take.
Thanks in advance.
Old Mar 18, 2015 | 08:09 PM
76larkman's Avatar
the wiring on DBW is no big deal to do. make gas pedal fit your car, plug the wire connector in. connect other end same short harness on the tach box. plug the main harness into tach box. throttle done. otherwise if you still want cable go to LT1Swap.com to do wiring conversion from DBW to cable. I did the DBW into my skylark, hardest part cutting/fitting gas pedal.
Old Mar 18, 2015 | 08:51 PM
L92 OLDS's Avatar
What transmission do you plan to use? I struggled with this question for quite a while and decided on DBW with a 4L80E. I prefer the drivability of a computer controlled transmission and the fact that you get cruise control out of the deal. If your trans requires a TV cable then you need to buy a cable kit with the truck TB. IIRC, the early cable throttle bodies are small so flow is limited. If you're looking for better flow you can buy aftermarket but at relatively high cost.
Old Mar 19, 2015 | 07:50 AM
Mikes64's Avatar
I have a 6.0 out of a 03(4L80) that I plan on using the DBW,I so have the stock harness and ECM, I dont think I have the tach box, I assume this is a must? I plan on keeping it as much as stock as possible for my conversion. Sorry to hijack, seem like a good post to ask.
Old Mar 19, 2015 | 08:54 AM
Black89Z51's Avatar
I'm trying to source a 4L80E for this build since it's eventually going turbo.
Looks like I'm going DBW since it's pretty easy.
As far as the tach box, no idea. I picked up the whole truck so I'm going to use the entire harness from that.
Old Mar 19, 2015 | 09:35 AM
76larkman's Avatar
on truck/suv the tach box is on firewall between master cylinder and driver fender. it has 2 plug in holes. 1 is from main wiring harness other goes inside plugs into pedal. you want to have pcm,pedal&tach box from same year so they match(thats what LT1Swap.com reccomends). its ok if pedal to long cause you can cut/bend fit it to your liking. just dont damage the sensor part of pedal.
