LY6 4x4
Old Mar 26, 2015 | 01:00 PM
DrWagon's Avatar
Default LY6 4x4
I'm doing a swap job and have my eye on a relatively local LY6 but the engine is set up for 4x4 output. I will be swapping into a RWD car and was wondering what the difference in the engine will be? Seems output shafts are different, but what should I expect to need to convert over?
Should I simply avoid any 4x4 engines and search for only RWD engines?
Old Mar 26, 2015 | 01:15 PM
1964SS's Avatar
The engines are identical. The transmissions are different. If your looking for a complete package with engine and trans then you will want it from a rwd vehicle. If your just looking for an engine to use as a stand alone then either will work.
Old Mar 26, 2015 | 02:10 PM
DrWagon's Avatar
Thanks so much! Trans is coming from another vehicle so sounds like I can move forward.
Old Feb 9, 2021 | 06:41 PM
indyjps's Avatar
Oops, wrong thread
