LS3/4L60E 1968 Chevelle
Old Apr 4, 2015 | 11:21 AM
Russ K's Avatar
Originally Posted by gofastwclass
Excellent work.
Thank-you
Very nice car. GREAT WORK !!!
Thank-you
Russ Kemp
Old May 24, 2015 | 03:58 PM
98 Raptor TA's Avatar
Originally Posted by Russ K
Since my friend was complaining about the gas fumes in his garage, I installed a charcoal canister from a 1997 Yukon and mounting tabs from a 3rd gen F-Body. The OEM fuel line is connected to the fuel tank vent to the canister, and the purge port of the canister is connected to the purge solenoid at the right front of the engine. Speartech added the purge solenoid wiring. Mounted the canister behind the battery. Also had to install restrictor with an 1/8" hole in the vent hose at the fuel tank.
I'm looking to do this to a LS swapped 73 Camaro. Did you have to use some kind of vapor separator? Or did you just run the tank vent hose to the canister and then the purge side to the solenoid? Also, what was the purpose of that restrictor you added?
Old May 24, 2015 | 04:44 PM
Imp709's Avatar
Default Gas tk straps
For the fuel system, a Tanks Inc fuel tank with the 255 LPH pump was used. Then a Corvette fuel filter/regulator with a 3/8" aluminum fuel line to the firewall just to the left of the brake booster. Russell -6 braided hose to the fuel rail, and Russell twist lock hoses from the tank to the Corvette fuel filter.
What did you make the gas tank straps with?
Was the material difficult to bend?
Im trying to install a fuel injection tank in my car need new straps
any info would be helpful.
Thank U in advance
Old May 24, 2015 | 08:55 PM
Russ K's Avatar
No vapor separator. Just ran then vent hose to the canister and the purge side to the solenoid. The restrictor was to help prevent excess fuel pushing into the vent line when the fuel tank is completely full.
Russ Kemp
Old May 24, 2015 | 08:57 PM
Russ K's Avatar
Thank U in advance
The straps, tank & fuel pump are from Tanks Inc.
Russ Kemp
Old May 24, 2015 | 08:59 PM
Russ Kemp
Ok that's what I figured. Do you happen to have a wiring diagram for that purge setup?
Old May 24, 2015 | 09:04 PM
Russ K's Avatar
I had Speartech add the purge harness, but it's a 2002 Camaro OS in a 411 pcm.
Russ Kemp
Attached Thumbnails LS3/4L60E 1968 Chevelle-purge-valve.gif
Old May 24, 2015 | 09:07 PM
Russ Kemp
Cool thanks. Now my only problem is it might be programmed out in the tune... I'm not sure what all the previous owner removed when it was tuned
Old May 24, 2015 | 09:19 PM
Imp709's Avatar
Russ Kemp
OK
Thank U
Old May 24, 2015 | 09:29 PM
Russ K's Avatar
You can't disable the purge valve with Hp Tuners. You can only disable the P0443 purge valve circuit code, but that won't stop the purge valve from functioning. But the car has to be in closed loop for the purge valve to open.
Russ Kemp
Old May 24, 2015 | 09:31 PM
Russ Kemp
Nice. That's what I was hoping for. I guess the code is just programmed out cause it goes into closed loop and throws no codes currently
Old Jun 10, 2015 | 06:45 PM
  #32
cpd004's Avatar
Russ, curious as to what made you use the earlier PCM. I have a similar combo that's running an 08 1500 5.3 2wd E38 and T42.
Old Jun 10, 2015 | 07:04 PM
  #33
Russ K's Avatar
Much simpler, as you don't need a trans range switch or TCM, easy to install a GM cruise control, cheaper pcm & pcm harness (Speartech). Plus the owner didn't like the look & fit of a DBW throttle pedal.
Russ Kemp
Old Jun 11, 2015 | 06:50 AM
  #34
Pop N Wood's Avatar
Very very nice. Enjoyed the build, thanks for sharing.
The car ought to be a dream to drive. Going to be a significant step up in every way from that 307/glide. owner should be thrilled.
Old Jun 11, 2015 | 07:05 AM
  #35
cpd004's Avatar
Russ Kemp
Thanks...fighting some tuning issues and looking for others running my same set up.
Old Jun 11, 2015 | 09:11 AM
  #36
Russ K's Avatar
Thank-you. Yes, the car drives like a new Camaro, has a very quiet exhaust, has a lot of power, cruises at 2100 RPM @75 mph, plus gets 30 mpg.
He is very happy with the car, and gets a lot of compliments at car shows/cruise nights.
Russ Kemp
Old Jun 12, 2015 | 10:14 PM
  #37
Motown 454's Avatar
Thanks for posting Russ its a great project. Nice work!
Old Jun 13, 2015 | 11:06 AM
  #38
350SS's Avatar
like the others said, great work and well thought out. I can appreciate how much time goes into figuring out how to make all those little details work (evap, cruise control, pedal leverage, etc...)
