1971 impala ls1 conversion
Old Apr 16, 2015 | 03:25 PM
Stixsdad's Avatar
Default 1971 impala ls1 conversion
I'm put a 98 ls1 in my 71 impala
Cpu in upgraded wire/fuse box
Fuel injection fuel line
Msd Fuel filter and pump kit
I need help with the gas tank do I need to mod are should I go fuel cell any advise would help
Old Apr 16, 2015 | 03:52 PM
Stixsdad's Avatar
Old Apr 16, 2015 | 03:53 PM
Stixsdad's Avatar
Upgraded headers and wires
Old Apr 16, 2015 | 03:55 PM
Stixsdad's Avatar
Default Gas tank
Thinking of doing this but would rather save the money on a regular one that will work
Old Aug 16, 2015 | 12:44 PM
chevryder71's Avatar
Default 71 ls1
what di you use for the shift linkage for your 71 ls1 swap?
Old Aug 16, 2015 | 12:45 PM
looks good so far!
Old Aug 16, 2015 | 12:47 PM
if i were you i would get a fuel injection tank off classic industries or make your own. there upwards to $1,000
Old Aug 16, 2015 | 10:27 PM
deuce4935's Avatar
Measure your stock tanks dinensions and compare them to the dimensiins of a later model fuel injected bbody(91-96). You might luck up, that would be a cheap alternative.
Old Aug 21, 2015 | 05:15 AM
he is correct is well.
Old Aug 21, 2015 | 08:28 AM
JustinEntropyRad's Avatar
Default Fuel
Some guys with the C10 trucks use Jeep Cherokee tanks with Chevy EFI senders/pump assemblies...seems to work on a budget
Or you can get fabbed units from Boyd's Welding..my brother has one in his C10, but they make everything
