1969 camaro
Old Apr 20, 2015 | 05:37 PM
Rforeman735's Avatar
Default 1969 camaro
I have a 69 Camaro and a 2003 Ls1 truck motor I going to swap oil pan to Camaro one want to keep truck intake and pulleys can any one tell me if it will fit this would be a great help and money saver thanks if you want to call me about this It would be great cell 228-861-5300
Old Apr 21, 2015 | 02:34 PM
Aston Tibs's Avatar
The LS6 intake has a ton of clearance, so I think the truck intake will clear no problem.
Old Apr 21, 2015 | 03:02 PM
1964SS's Avatar
If your 69 camaro has stock subframe and steering then the LS camaro oil pan will not fit without being modified and welded back up. I believe the steering gets in the way.
Old Apr 21, 2015 | 07:01 PM
76larkman's Avatar
intake depends on the mounts you use. the adapter plates using clam shell style mounts puts motor up higher.
