f-body engine removal question. need opinions!
I know what works for me and how I have done things, but what is the easiest way for you to remove an engine from f-body Camaro or Trans Am? Just would like some opinions to settle an argument
Bottom three times for me, once you do it the first time the next time is a lot easer. I don’t like the idea of having to pull the heads first and then install the heads once the engine is back in.
Interesting ..like maroonls1z pointed out.. all I have heard is the from the bottom is easier. . Good to know out the top is a good way... any one try both ways ,found one way better then the other?.. I don't like the idea of raising the front that high to get it out from the bottom. (No lift for me to use)
I think out the bottom is insanity but to each his own. Out the top is quick without brake lines or steering to eff with. The only reason GM started this out the bottom bs is it get people bk to the dealers
. It scares a bunch of hobbyists off.
. It scares a bunch of hobbyists off. never even thought about the brake line issue myself
