What spark plug & wires should run?
Old Apr 22, 2015 | 12:45 AM
eez28's Avatar
Default What spark plug & wires should run?
Ls1, Ported 243s, victor jr, spraying 150-200.
I was thinking TR6 and msd plugs
Old Apr 23, 2015 | 09:16 AM
1964SS's Avatar
The plug wire brand really isn't important. You just need a good quality set of wires. Same goes for the plug to a point. MSD is a brand. You should be more concerned with the heat range of the plug when spraying. What is the car used for? Racing only or street use as well? You should be running a plug about 2 steps colder for your spray setup, but if used too much on the street without spray then the plug may be too cold and you might need to run a set for street and a colder set for strip use.
