lsa blower swap?
The boost solenoid is computer controlled and the older LS1 PCMs which I will be using cannot control them. All they do is limit boost under certain circumstances
Have an LQ9/T56 for my C3 corvette project.
I want to do a PD blower, and keeping the cost down is always a plus.
Sub'd
With a taller hood I dont see any reason you couldnt pull this off. plenty of room for the FEAD, so your height is the only limiting factor
Sorry for the thread-jack. Back to LSA superchargers.
I plan on using the L-88 hood for clearance. Wanted to use that hood all along for appearance reasons and to eliminate the wiper door anyways.
With this swap have there been any major obstacles? Like setting up the bypass valve? Is there clearance for the coolant crossover? are there issues with the valley cover or will the LS2/6 cover work?
Here is a LSx in a C3:
As you can see, there is nothing to interfere with the blower assembly. It just goes up. Wipers, HVAC etc can all stay put. The CTS-V/ZL1 FEAD systems are similar to Fbody LS1, which fits just fine. There is ample room for the balancer to crossmember, so again good fit. I dont see why C5/6 style bracketry wouldnt also work, there is plenty of space. Theres nothing extra from a standard LS1 conversion for a LSA C3
The bypass valve is a non-issue. Bolt it on and make sure the vacuum line is hooked to the top port. The bottom port is for the boost solenoid and is optional for a conversion
I have both an F-body and the LQ9 FEAD.
I need A/C, I live in the phoenix area, and I know I have to mount it high on the passenger side. I plan on using VA for my HVAC stuff.
So, in your opinion what would be most feasable?
Buy 8 rib truck pulleys, get an A/C relocation and offset the pulley on the SC?
Or sell both of my FEAD's to offset the cost of an LSA balancer, and aftermarket corvette FEAD setup. With AC relocation of course.
The problem I see running into is on the LSA the tensioner for the SC pulley is up where I would be putting my AC bracket.
I hope that my asking these questions and getting answers is helping the OP on his decision making as well.
I dont recall there being much in the way of a low mount setup aside from the pass motor mount arm. A welder makes that a small job
Good luck on your swap. I did a LS1/T56 into a 73 vert last year. Lots of fun
Hi i am currently putting a lsa in a 86 corvette and had planned on using my 00 6.0 truck pcm but i am reading now that it will not control the boost solenoid, is there any way to use my pcm or will i need one out of lsa vehicle or is there an aftermarket controller???
thanks in adavance!
thanks in adavance!
Every pd blower needs the bypass valve to operate. When the valve sees vacuum like at idle, it holds the bypass blade open routing the inlet air around the superchager rotors rather than through it. When throttle occurs and vacuum drops, the valve closes the bypass blade allowing air into the rotors and boost to build. All that it takes to hook up is the vacuum line from the vacuum/boost port on the supercharger lid to the bottom of the bypass diaphragm.
The boost control solenoid is the electronic side and is not required in our application. The e67 ecm uses it to prevent over boosting in certain situations by forcing the bypass valve open under boost.
Aftermarket Corvette Accossory drive - These go in the $5-600 range w/o A/C.
I have to have A/C because I live in phoenix.
I can't use the stock low mount in my corvette without major frame work.
So CTSVCADDY found a place to order High mount A/C that has LSA S/C idler pulleys integrated.
I'm patiently
waiting for the result that he had with the set up. Aftermarket Corvette Accossory drive - These go in the $5-600 range w/o A/C.
I'm patiently
waiting for the result that he had with the set up.GMPP sells a "modified" CTS V acc drive setup for just under a grand with everything you need except AC and balancer which high mounts the alternator. Oh, and the balancer is like 130 on amazon.
Please post the high mount ac info when you get it, I'll need it down the road for my build.
The corvette accessories are on the same rib alignment as the CTS-V, and it mounts the alternator high with the PS pump low. Essentially the GMPP set up you're speaking of is the same as a corvette set up. So I'd rather pay ~$600 for an aftermarket, than ~$1k for the "modified" CTS-V set up.
I understand the CTS-V set up comes with the S/C idlers, but since I need to mount my A/C high the stock idlers would be useless to me anyways.
Thanks for the info on the balancer though. I hadn't even thought to check Amazon. I shop on there all the time too.
Does the aftermarket one include the alternator/PS pump?
Do you have a link to the AC mount that works w/ the supercharger belt? Looks like we're doing similar things here haha. I was assuming I can find an AC mount that will go on the inner belt and not alter the supercharger belt/idler?
I've gotten a few things off Amazon for cheap, like LS7 throttle body for 130, that balancer, etc.
http://www.jegs.com/i/Chevrolet-Perf...ductId=2806347
Includes alt. (150amp usually), ps pump, and the necessary brackets and idler pulleys. From what I understand the LS3/LS7/LSA waterpump is the same, and you'll need one for the proper bosses to install the S/C idlers. That may not be 100% correct, but I'll get one anyways to have the replaceable thermo.
If you scroll up to ctsvcaddy's post above he gives a place where he found and ordered a high mount A/C w/supercharger idlers from a company called street and performance. (google will get you there quick). Waiting on him to post the results of the test fit before I make any further decisions/purchases.
