LS3 into a 2006 solstice / Electrical
1) Did you have to cut your trans tunnel to get the 6L80e in there? If so, is it noticeable?
2) Is there a major difference in the swap of I start with a base model vs a GXP? I'm thinking the suspension might be heavier duty in the GXP.
3) How is the handling with the LS in there?
4) How wide of a rear tire can you fit in there?
Thanks
