brake booster filter required
Old May 17, 2015 | 03:46 PM
shrike's Avatar
Default brake booster filter required
hi,
my conversion is a 5.3 engine with the fuel injection in a 1987 Cadillac Brougham that previously had a carburetted 307.
Is it necessary to use a brake booster filter? I read that ssometimes it is useful so crap doesn't get into the manifold.
Old May 19, 2015 | 08:17 AM
1964SS's Avatar
It's actually to keep fuel vapors from damaging your booster. I don't believe any of the newer vehicles use them at all since they are a dry intake system. If you want to keep one then it will not harm anything, but it's not required.
Old May 19, 2015 | 10:13 AM
tfi racing's Avatar
If you have it,go ahead and use it.If not just forget about it...
Old May 19, 2015 | 03:59 PM
imma_stocker's Avatar
Not necessary, as 1964 said they were initially put in place to keep fuel from damaging the booster diaphragm and seals.
No need for the filter, if you feel one is important you can use an inline separator from local hardware store (same kind used for building a PCV catch can system). This part needs to be oil/gas compatible so the filter element doesn't crumble and get sucked down into the manifold.
Old May 22, 2015 | 09:11 PM
shrike's Avatar
No I don't have one. I'll spare the money then. Thanks guys
