do i need a converter? 1958 GMC
im not sure if this is the right section to post this but i had a cam installed on my 5.3 for my 58 gmc swap and im not sure if i need a converter with this size of cam
lift 513/556
dur @.50 229/240
int cl. 114.5
i bought this used cam off one of my buddies, he claims i wont need a converter but what do u guys think?
my truck will only have exhaust and cam nothing crazy
another question, qould it be bad if i ran the stock exhaust manifolds?
No harm running the stock manifolds, but again, you're missing out on easy power if you don't do long tubes.
The guys at PI (Precision Industries) are very helpful, and they actually give you a little interview over the phone before they even build a converter for you. If you want the best of the best, it's going to run you about $850. However, before you freak out, there are plenty of other options available from other companies. I would suggest calling them though, figuring out what they suggest for your specific vehicle, and then shopping around for a converter with similar numbers.
