4l60E new swap - Will not shift??
It is a 2002 LM7 4L60E out of an 02 2wd Avalanche. BP automotive harness and PCM reflash.
When in drive it is trying to pull out in I think 3rd. If you pull it down into low it will shift to low but will not change gears. I took it to a GM dealer who is a friend and they pulled the pan and checked voltage to the solenoids and everything checks out. They went ahead and replaced the solenoids just to be sure, the service manager and both transmission guys now say they are 100% sure the problem is not in the transmission. They are telling me the solenoids are activated by ground and the 1-2 solenoid is getting ground like it is supposed to but the 3-4 solenoid is not. They also checked the pins in the harness and see sure that the problem is not with the harness. I hate to keep spending money and replacing parts.
I'm pretty bummed with the whole thing at this point. I really thought it would have been running a month ago. It still has an oil leak (front seal), no exhaust, a/c hooked up and the front end aligned.
The harness will have a round plug that has one pink wire. This pink wire should have 12 volts with the key on and everything is enabled by ground through the PCM.
It could be as simple as a fuse or as complicated as a wiring issue depending on how your harness was built. Obviously I hope it's a fuse.
By the way, your comment "They are telling me the solenoids are activated by ground and the 1-2 solenoid is getting ground like it is supposed to but the 3-4 solenoid is not. They also checked the pins in the harness and see sure that the problem is not with the harness" only leaves one option. If the 3-4 solenoid isn't getting a ground signal the problem can only be in the harness or the PCM. The GM Techs say the harness is good it must be in the PCM. If you have a spare PCM you could try that - even though they rarely go bad, I've actually had it happen (for a coil) but you probably don't one laying about.
It appears my PCM was programmed for a 4L80E and not a 4L60E. A 4L80E does not have the 2-3 shift solenoid so the computer was not sending the proper ground to the 2-3 shift solenoid, or at least that is the way it was explained to me.
I appreciate all of the help.
