Fuel pressure
Old May 25, 2015 | 03:31 PM
jimmyg's Avatar
Default Fuel pressure
Using racetronix 340 in tank set up with corvette filter/ reg. 65 lb at an idle but when I shut it off goes to 0 seems like it held pressure before but not now anybody?
Old May 25, 2015 | 05:48 PM
Project GatTagO's Avatar
Got any visible leaks? 65 seems pretty high for a Corvette filter/regulator...
Andrew
Old May 25, 2015 | 06:43 PM
jimmyg's Avatar
I changed the filter to a wix . Seems to run a lot better , plus it quieted down fuel pump, and hesitation is gone . The one I took out was a pronto I got from speedway .right now it's a pain to check fuel pressure because alt is in the way. I had to remove it to fit gauge on it. Thinking of getting a permanent gauge , but no visible leaks. I'm thinking the tank must of had a bunch of **** in it even though it's new
Old Jun 1, 2015 | 07:40 AM
jimmyg's Avatar
Finally put a gauge on it 58-59 lbs all the time
