DBW going into limp mode
Old May 30, 2015 | 07:55 AM
garys 68's Avatar
Default DBW going into limp mode
I've got an 02 escalade LQ9 in my 68 corvette with a Richmond 6 speed. Stock tune, ecu, TAC, and pedal.
It occasionally loses the DBW throttle (limp mode, just idles), usually just getting into the throttle when accelerating from a stop. Shutting it off and disconnecting the battery resets everything and it will work fine. It also never gives me a check engine light.
I noticed it usually occurs after I get the car out of storage and seems to be in the same throttle position, so I assumed it was a dead spot or corrosion in one of the pedal position sensor potentiometers. I replaced the APPS but it still occasionally occurs. The TAC is also new. Wiring and connectors look good.
I've never been able to check the ecu for readings on the pedal sensor since I've never had it occur in my driveway.
My next step is the TPS but thought that would give a CEL.
Any other thoughts?
Old May 30, 2015 | 08:49 AM
33willys's Avatar
Default Dbw
When I was tracking down my problem I found a video on the 'net that discribed your symptoms, random and when under a load. In that case (and others) the problem was one wire going to the throttle body was loose. Very hard to detect and somewhat common. Guess they had some bad crimps on just the one wire and only held in by a couple of strands. Under load the wire is unable to keep up, causing a mismatch signal and limp mode. My scanner is able to read the "U" codes which is where something like that will show up. Best bet is to search the net and the video will tell all.
Old May 30, 2015 | 09:27 AM
pdsq98gt's Avatar
There was a bulletin about the throttle body wiring being broken inside the insulation about an inch from the throttle body. If I recall its almost always the yellow wire. Yours may be something different though. What MAF do you have?
jmyers's Avatar
Default Pedal
I have also replaced the pigtail before but the only thing that fixed it permanently, was to go to the dealership and have the computer reflashed. I tried to change some things in my dads transmission settings with hp tuners and that crap with the gas pedal started. After exhausting all other resources, I had it reflashed at the dealership and it never happened again. Good Luck.
Old May 30, 2015 | 03:09 PM
garys 68's Avatar
I saw the tsb, but saw it was for 03-05 TB. Also, I never got a code.
I'll check it anyway
Old Jun 6, 2015 | 03:59 PM
garys 68's Avatar
Update......
Wiring checked out OK.
But I noticed the throttle response seemed a bit sluggish before it went into limp mode. I decided to pick up a used TB with motor and TPS. It was about the same price as a new TPS. The used one was really gunked up on both sides with carbon, oil, etc, so I cleaned it up and went to put it on.
This is what the old TB looked like inside. I'm guessing the excessive buildup was causing a delay in opening off throttle resulting in an error and limp mode. I actually read about the same issue somewhere years ago. New/used one is bolted on and runs great. Now I guess I've got a spare to clean up.
Old Jun 9, 2015 | 07:22 AM
garys 68's Avatar
Well, new TB and TPS, I'm still having the issue, but still wont throw a code.
As a matter of fact, my tune wont throw a code if the pedal is completely disconnected from the TAC. Is that normal?
Old Jun 9, 2015 | 08:50 AM
aknovaman's Avatar
Plz post pics of your pedal and TAC module as well as the PCM file.
Old Jun 9, 2015 | 09:14 AM
garys 68's Avatar
aknovaman,
The pedal and TAC are correct for the vehicle (02 escalade, LQ9). The car ran great for 5 years as is. The intermittent pedal control loss just started, it also is getting more common.
I replaced the pedal APPS thinking that was the issue, but still have the intermittent problem. Also did the TB cleaning and relearn. TAC was new in 2010.
I contacted the tuner for details on the file. I don't have hp tuners, etc, but it seems disconnecting the pedal should throw a code.
Old Jun 9, 2015 | 11:50 AM
garys 68's Avatar
One additional note. I can disconnect the TAC entirely, both plugs, it looses idle control but still wont throw a code.
Old Jun 9, 2015 | 09:37 PM
aknovaman's Avatar
Shoot me pm with your email. I have connections in STL that can assist.
Old Dec 9, 2015 | 02:56 PM
HiggZone's Avatar
Was this resolved? What was the fix? I just completed a LM7 DBW swap in a jeep, and have a very similar issue
Old Dec 9, 2015 | 04:04 PM
garys 68's Avatar
Bad wire connection between pedal and TAC. Original tuner disabled all DBW codes. New cable, all fixed. Getting any codes?
Old Dec 10, 2015 | 08:02 AM
aknovaman's Avatar
His tuner was an idiot and his file was all jacked up so I fixed it. Gary fixed the wiring issue.
Old Dec 10, 2015 | 08:23 AM
HiggZone's Avatar
I borrowed a buddys PCM that is DBW, and it ran perfect in my jeep. I'm thinking I have a messed up tune, or a bad pcm.
The code it was throwing is P0654
Old Apr 26, 2025 | 10:55 AM
Dnilz's Avatar
Hey man! Im hoping you reply to this message as you posted on here a decade ago. I'll try to be brief, i did an LS Swap on my truck and its doing the exact same thing, i was wondering if i could get some help.
Old Apr 26, 2025 | 04:54 PM
Who are you asking?
Old Apr 28, 2025 | 09:20 AM
garys 68's Avatar
My issue was a wiring/connector issue. Original tuner disable ALL codes, so it was hard to diagnose. What's your swap info, issues you're having, any codes?
Old Apr 29, 2025 | 05:32 PM
mrvedit's Avatar
Moderator
@Dnilz - Please start a new thread if you need assistance. This is an ancient thread and I am closing it.
