AC pressure sensor solution
Old Jun 7, 2015 | 07:04 PM
Renegade6's Avatar
Default AC pressure sensor solution
I've seen some of the solutions on here for grafting in the LS pressure sensor fitting. Because I went with EZ clip fittings, I ended up having to fabricate something.
I purchased the weld on adapter from: http://autoacfittings.com/R134a-Stee...-Port-4166.htm or from Ebay http://www.ebay.com/itm/251621696215?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I then used a Red Dot EZ clip R-134 high pressure fill adapter, cut off the port and tig welded the fitting to it.
It should work but, may be a while at the rate I'm going.
Old Jun 8, 2015 | 02:11 AM
gofastwclass's Avatar
I wasn't aware these fittings were available individually, thanks for the tip. Now I can fix the AC in my truck on the cheap!
Old Jun 8, 2015 | 06:43 AM
casias's Avatar
Thanks for the information.
