Corvette PWM connector kit?
Old Jun 23, 2015 | 08:48 AM
samckitt's Avatar
Default Corvette PWM connector kit?
Anyone have any interest in this new connector kit? I have a few interests, if there is more I will order the parts & put together a kit to sell. It will include the main connector body, 4 power terminals, 1 signal terminal & all the wire seals to wire it up yourself. This will allow the ECM to control the fan speed, not just on/off, but soft start & ramp up speed related to engine coolant temp. Can also be wired up so when the AC is on the fan will run at variable speeds compared to the AC pressure. For these parts listed above will be $55 shipped. I may also order another connector that is the male & female parts required for a disconnect in the circuit. This is two connector bodies, 4 power terminals (male & female), & 2 signal terminals (male & female), and all seals required. That probably be another $25 shipped.
The other connector that allows removal of fan (PWM module is mounted on fan):
