1956 f100
I have a 1956 F100, 6 cyl I want to swap a LS base into. I was hoping to get some help with the following:
1. Other than adding blocking plates for IFS/IRS setups to the frame, what else should I do to strengthen the original frame for the added power?
2. Has anyone used the motor mounts for the LS swap from Mid-Fifties website? If so, what were somethings you did or didn't like about the placement for the engine?
3. Anyone have a good write up or thread covering their build for this type, I have looked but am sure I have just missed it or just haven't found what I am looking for.
Thanks and looking forward to learning more from you all,
Volition
I swapped in an L92 6L80 to my 51 ford F1
Very happy with the results.
Here's a photo chronicle of my swap.
1951 Ford Truck:
https://www.icloud.com/sharedalbum/#B0855Z2WMGOKzTn
My setup dynod stock at 340hp and 350 ft lbs at the wheels.
If I was starting from scratch I'd have used the corvette control arms vs. heidts. My truck came with the heidts.
