Question on 6L80 brake switch
Old Jul 7, 2015 | 06:04 PM
Blazincopper's Avatar
Default Question on 6L80 brake switch
Ok, for you guys running a 6L80 - how did you wire it to the brake pedal? Should be Pin 9 on the ecm and pin 6 on the tcm spliced together to the brake pedal. Did you wire it 12V when brakes are applied or 12V when brakes are not applied? Also, is anyone reading voltage coming from the wire from pin 6 and/or 9 when the key is on and its not connected to the brake switch?
Old Jul 7, 2015 | 08:27 PM
jcvett56's Avatar
http://www.speartech.com/v/vspfiles/...ns/LS58X6L.pdf
Wire gets +12V when brake is applied and it's grounded when brakes are off.
