Replacement LS6 MAP sensor to eliminating vac lines?
Old Jul 9, 2015 | 06:28 PM
BBPanel's Avatar
Veteran: Marine Corps
Default Replacement LS6 MAP sensor to eliminating vac lines?
I've seen where the vac ports are cutoff and epoxied, etc. but does anyone make a replacement plug w/o the vac ports on it and only the MAP sensor hole?
