2012 4l65e trans install
Old Jul 17, 2015 | 12:06 PM
cru_zn_29's Avatar
Default 2012 4l65e trans install
Well I am new to the ls1 site and looking for some direction. I picked up a 5.3 from a 2008 Avalanche that I will be installing in a 66 C10 and I need to find a trans. I have located a 2012 4l65e from escalade all wheel drive. I know I will need to change the output shaft and tail housing what other problems am I going to have. Thanks Kenny
Old Jul 18, 2015 | 03:27 PM
Jimbo1367's Avatar
I'd look for a 4L70E instead being its going into a heavy trruck
Old Jul 18, 2015 | 04:17 PM
cru_zn_29's Avatar
The truck is a 66 C10 short bed daily driver
Old Jul 18, 2015 | 04:24 PM
jcvett56's Avatar
For purposes of making it easy on a wiring harness grab a 4L60 or 4L70 that predates 2008 so you don't have the 17 pin wiring in the transmission.
Old Jul 18, 2015 | 04:28 PM
cru_zn_29's Avatar
I have the harness that came with the 5.3
Old Jul 20, 2015 | 07:57 AM
gofastwclass's Avatar
I would stay away from all wheel drive transmissions in a two wheel drive situation. To change the tail housing is a simple six bolt swap. To change the output shaft requires a complete tear down of the transmission plus the physical parts. If you budgeted for this, keep rolling but I'm willing to bet that additional cost makes the AWD transmission a lot less of a good deal.
Old Jul 20, 2015 | 10:28 AM
cru_zn_29's Avatar
Thanks for info. I will keep looking for one I don't have to do a bunch of work on. Yes I
do have a budget
