03 mach 1
Old Jul 18, 2015 | 09:06 PM
rtauto3000's Avatar
Default 03 mach 1
I am finishing up a swap in to my 03 mach1 swap and trying to get all the factory gauges to work I have everything but the tach working. I know it goes over the scp network.
Question1 What signals/ sensors are needed for the pcm to give tach signal? does it read off the coils or does it read of the crank and cam sensor? ( I dont need the gm tach out put, I cant find anything for the factory ford pcm)
Question 2: Does the Ford PCM have to see the engine running to engine the cooling fans? My fan would not kick on at 195 or 205 I can turn the fan on hi and low with the scan tool,
Question 3: Does the Ford PCM have to see the engine running to send a/c clutch signal to engage it?
Any help would be great full thank you all in advance.
__________________
Old Jul 19, 2015 | 02:20 PM
zipster's Avatar
Does your speedo work? I am doing a 2000 GT swap. I opted to go with 1997 gauges, that way I can eliminate the Ford EEC5.
