Help me on my time line
To give some more perspective, I'm 32 and have a full time job. I also have four kids that, considering my wife's schedule, I have all by myself every other weekend. My mechanical experience is limited to oil changes and brake jobs, so this will be the most intense task I've taken on.
I have friends with a lot more experience that I can call on for help, but I'd like to do as much as possible on my own. So here's my rough schedule.
Jan-May
Buy engine/trans
Possibly rebuilt both depending on condition/mileage
Build up engine to respectable numbers (325-350)
June-Aug
Buy vehicle and fix necessary components
Prep and install engine/trans
Thoughts? It seems more than resonable to me, but anyone with experience can feel free to correct me.
A lot will depend on what sort of engine you get, how much work you have to do to it, etc...Also, however much you think it will cost, double it, and you will be close.
Do yourself a favor, buy the lowest mileage engine you can afford and leave it alone. At most just do a mild cam and valve springs, and don't mess with it. I paid $2000 for a LH8 (Gen IV aluminum block 5.3L) that had 386 miles on it. Some would say I overpaid, but to me it was totally worth it.
For g-body swaps, go with the Holley mounting system. Also consider the Holley HP if you get an engine that does not have a harness and ECU.
I did my Cougar swap in less than a year. Bought the engine last summer, then started collecting parts over winter. By the time it warmed up enough to work on the car, I had most parts on hand. I am still tinkering with it, but it is a running, driving car, and that's a swap that doesn't have any swap kits available. Then again, I have been tinkering with cars for almost 30 years, and have done 4 LS swaps.
Andrew
Other than that, for simplicities sake, keep the 200r4 that comes with the 87's of turn it right in as a core for a rebuilt one. You'll save quite a bit of time, money and tinkering not having to figure out drive line angles and trans mount locations or driveshaft lengths. When I had my '87 mcss I went for a rebuilt trans thar was built for a gn. On the other hand a 4l60 shouldn't be too much trouble.
But limiting the physical size of the trans mating to your swapped engine will help out tremendously and save you some head aches.
Wish I still had mine... Good luck!
