Ls1 cluster in 87 mustang help
Old Aug 8, 2015 | 11:16 PM
bjamick's Avatar
Default Ls1 cluster in 87 mustang help
Here is the pin out for the 87 stang (it's on the 2nd page btw)
http://www.stangnet.com/tech/cluster87-93.pdf
I am needing to know which wires these particular wires go to.
http://i191.photobucket.com/albums/z...Cconnector.gif
Hopefully that works but that's the ls1 cluster pin out.
I need to know which wire on the ford cluster goes to these particular pins on ls1 cluster.
Pin A3 - pink wire ignition 1 voltage
A10 - orange wire battery pos voltage
A13 - purple/white wire instrument panel lamp control
B1 - brown wire park lamp supply voltage
B9 - gray wire instrument panel lamp supply voltage
The rest I've already hooked up, but these I'm not for sure which on the stang cluster does this. I know a few guys have done these cluster swaps in mustangs and other cars so hopefully someone can help me out so I can get this cluster done and get dash back together.
Thanks
