Wiring radiator fan
Old Aug 24, 2015 | 01:52 PM
33dogstreet's Avatar
Default Wiring radiator fan
Just bought a 68 Chevelle with an LS1 out of a 2002 Camaro SS. It is currently wired up to use a manually switched radiator fan. How would I go about restoring it to the factory thermostat controlled switch?
Old Aug 24, 2015 | 11:38 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Welcome to LS1tech!
Let's move you to here in the conversions section.
Neither the 1968 Chevelle or the 2002 Camaro used a thermostat controlled switch for the fan.
The 2002 Camaro had a PCM controlled set of fans.
What are you using to control the fuel injection system of this engine in the Chevelle?
https://ls1tech.com/forums/generatio...g-threads.html
Old Aug 25, 2015 | 06:16 AM
Originally Posted by Paul Bell
Welcome to LS1tech!
It is the stock EFI from the Camaro.
Old Aug 25, 2015 | 09:18 AM
Paul Bell's Avatar
The PCM for the Camaro controls the fans. It's a pretty good system and recommended for use on swaps such as yours. Guys with trucks change to E-fans and get the PCM control working.
The LS1 fan setup for the F-body PCM runs both fans in series for low speed and in parallel for high speed when needed. The PCM has two pins that it grounds and these work a few relays that power the fans as needed.
Old Aug 25, 2015 | 01:00 PM
68birdls1's Avatar
Check out bp automotive for a complete relay setup ready to go. Just have to connect a few wires and your done
Old Aug 26, 2015 | 01:14 PM
hookemdevils22's Avatar
If it's a 2-speed fan, and you want to retain the 2-speed functionality (which is recommended), buy a Volvo fan relay. It doesn't get much cheaper (~$25 on eBay) + easier (5-wire hookup) than that.
In the event you can't find the fan control wires and/or don't want to trace them back to the PCM, you can use a dual-temp switch to control low and high speed.
More info here
Wire hookup, from left to right:
OUT
2 - to fan high speed
1 - to fan low speed
IN
2 - to PCM fan 2 control (blue connector at the PCM, pin 28; wire should be dark blue)
1 - to PCM fan 1 control (red connector, pin 43; dark green wire)
30 - fused battery feed
Old Aug 26, 2015 | 01:25 PM
Paul Bell's Avatar
Be aware that both fans in parallel at full speed can draw up to 40 amps. That full speed fan GM uses is good for more than 40 amps.
