o2 sensor wiring
Old Aug 31, 2015 | 07:46 PM
lilrobo's Avatar
Default o2 sensor wiring
i am looking for the wiring diagram for sensor 1 banks 1&2 ( manifold only ) i have 4 prong o2 sensors for a 06 5.3 ecm is blue & red plugs , iam tracing out my wiring i have 1 not working dont know which one ,i know there is 12 volts on the pink wire with the key one ,, dont know anything else right now ,, i want to ohms them out to make sure they aren't broken , them i test for power
thanks
Old Sep 1, 2015 | 02:09 PM
1964SS's Avatar
How do you know you have one not working, but not know which one it is? The ECM will tell you which O2 sensor is having the issue.
Here's a link that could help you out.
http://lt1swap.com/03_5.3-6.0_o2.gif
Old Sep 1, 2015 | 03:09 PM
lilrobo's Avatar
when i had it dyno, i had 1 not working , so my guy turned them off , i need to have them turned on before i can do any searching ,, i do need a diagram
thanks
Old Sep 1, 2015 | 04:47 PM
lilrobo's Avatar
all my wires check out with ohms , now i have to wait until i get everything back on,, thats the kicker the guys used is a hour away, they dont match the diagram you posted ??
pass side
color pin
tan 26
ppl 66
pink 19
ground chassis ground
drivers side
pink 19
tan/wht 29
ppl/wht 69
Old Sep 1, 2015 | 05:09 PM
1964SS's Avatar
Strange, Maybe your harness is older then you thought. Here is a link to the general info page. Check out the 01-02 isolate ground diagram near the bottom. Looks like what you are describing.
http://lt1swap.com/vortec_o2_sensors.htm
Old Sep 1, 2015 | 07:18 PM
lilrobo's Avatar
thsi is what i have
2001-02 4.8/5.3 with case ground sensors
