6.0 ls1 in 67 camaro
Old Jun 8, 2004 | 02:27 PM
oramac7691's Avatar
Default 6.0 ls1 in 67 camaro
I am instaling a 6.0 in my old camaro. will the stock oil pan fit with s&p mounts? should I use a t56 from a ls1 or lt1? is it hard to convert to a hyd. clutch? can I reflash a gmc truck ecm with the same performance I would get out of a camaro pcm?
Old Jun 8, 2004 | 06:27 PM
Steve1969LS1's Avatar
No.. you will have to notch the oil pan.. should be able to use a LT1 T56.. hyd clutch shouldnt be hard, its been done many times. Not sure on computer..
the LS1 is 5.7L not 6.0.. or is this out of a truck?
Old Jun 9, 2004 | 11:33 AM
oramac7691's Avatar
Default 67
its a 6.0 out of a truck
