ls swap problem
Old Sep 23, 2015 | 06:43 PM
BallerCamaro21's Avatar
Default ls swap problem
ok I have a 96 trans am and I swap a 5.3 motor into it and everything is in and all but I have two problems. 1) the only way I can get it started is to spray brake clean in the mass air flow and then it will run. After I shut the car off I can restart the car and it fires right up. what could be the problem?
My second question is that when I have the car running if I hit the gas pedal the car act like it wants to die. But if I lightly ease into the throttle it wont dies but the car revs up to only like 1300-1500 and then stop and cant rev past that at all. What could be that problem?
Could both issue be cause by the same problem?
Old Sep 23, 2015 | 07:48 PM
S10xGN's Avatar
The 1st problem sounds like a dry fuel rail. When you turn the key, the fuel pump should prime for 2 secs and pump up the rail. 2nd could also be FP related. Put a gauge on the rail, install fresh fuel filter, check FP relay, etc...
Old Sep 23, 2015 | 08:06 PM
I have a corvette style fuel filter that is brand new I have install and yes the fuel pump does turn on when I turn the key on and everything. I also have a fuel pressure gauge sensor install at the end on my fuel rail and have a gauge inside the car and when I turn the key on the gauge reads 58-60p psi with the key on engine off
Old Sep 24, 2015 | 04:47 AM
jimmyg's Avatar
Take the injectors out and clean them .also , make sure you have a good filter reg, wix, gm, etc I had same prob with a pronto filter
Old Sep 24, 2015 | 07:03 AM
Does anyone know what the part number is for the wix filter?
Old Sep 24, 2015 | 05:28 PM
bczee's Avatar
WIx #33737 is the Corvette FPR (GF822).
