LS1 Novice need harness/ECM help
Old Jun 8, 2004 | 10:42 PM
67lsrs's Avatar
Question LS1 Novice need harness/ECM help
Ok, I'm putting together a 67 camaro with an LS1. The motor is from a 98/99 TransAM and I bought a ECM on EBAY from a 98 Z28. I planning on using the painless harness which specifies the GM # for the computer that I have. Is there anything I should be aware of before i spend the money on the harness? Without knowing for sure what the motor was out of 98 or 99 I'm a little paranoid about buying the wrong stuff. Or can the computer be flashed to any combination?
Also has anyone been able to get the factory LS1 oilpan (camaro pan) to fit without mods in the 67 camaro chassis???? If so could you give a hint on the motor mounts??
Thanks for any help
Old Jun 9, 2004 | 01:10 PM
LS1swap's Avatar
Thanks for any help
Do you have the stock harness for the engine now? If so you can modify it yourself or have some one like speartech modify it for you. You will need to figure what harness you have. 98 and 99 are different
Old Jun 9, 2004 | 06:02 PM
67lsrs's Avatar
Question Harness
As of yet I dont have a harness, I was looking to buy the painless harness, and use the 98 z computer #16238212. I just dont know what sensors and such the motor has, or wont that be a problem?
Old Jun 10, 2004 | 01:23 PM
LS1swap's Avatar
You will need a 98 harness if you have a 98 pcm I purchased mine through gmpartsdirect for $255.49 the part number for the stick harness is 12177561. You would also need the two coil harnesses pn: 15301401 $47.38 each. If you went that wrought you would also need to build a VATs module or have the pcm reprogramed to delete it. Which is something you may want to consider to get rid of emissions. I don't know for sure about computability of all the sensors but I think most if not all are compatible from 98 99. This is just some options. I have not personally dealt with speartech but have heard nothing but good about them. Another good investment would be a set of helms manuals
Old Jun 10, 2004 | 09:02 PM
boondiggys's Avatar
i thought the 98 was different from the 99-up . i would be sure what year the motors from first before you go buyinganything unless like swap said you can use any motor just gets differed from the pcm?
Old Jun 12, 2004 | 01:35 AM
67lsrs's Avatar
Default wrong number on pcm
I checked the number again on the PCM and it isnt what I thought.
The hardware number is 16220610
Service Number is 09354896
Do I even have an LS1 PCM?
Thanks
Old Jun 12, 2004 | 08:13 AM
DaleMX's Avatar
98's have the perimiter bolts on the valve covers, 99 and up have the bolts in the center.
Dale
Old Jun 13, 2004 | 08:12 AM
LS1swap's Avatar
the service number on my 98 pcm is 16238212 and the hwd# 16239740 are you sure about that service # ???? I ran it on gmpartsdirect and came back with no results
Old Jun 15, 2004 | 11:25 PM
67lsrs's Avatar
Yes, thats the number that is on the tag.
Old Jun 15, 2004 | 11:32 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
That's the PCM for the 99-00 LS1 and Gen 3 trucks.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old May 17, 2006 | 06:49 PM
jeremymcclure's Avatar
16238212 pcm
Fits 1998 Camaro,Firebird,Corvette
Also fits 1999-2000 medium duty trucks
1998-1999 "P' chassis trucks
Old May 17, 2006 | 06:53 PM
i know this topic is MAD old but i figure the info is here now for future searchers!!!
thank you im hear all week
