"1997" Camaro LT1 to LS1 Swap Thread
We start out with my donor car which I picked up for a cool $2500. I've been working on parting it out to make back some cash and its almost paid for itself!
Sitting in the wreckers yard the day I got it:
All stock! Just got her home, you can see the carnage somewhat.
Factory Hurst shifter
Got it all stripped out to nothing
Preparing the motor to be removed
Dropping it out!
She's on the floor
Taking it off the stock K member and sitting it on the new BMR K with poly motor mounts.
Brian Tooley Racing trunion upgrade while it's in my lap
And where we stand today with my car:
At this point I'm in the process of removing the LT1/4l60e out of my car and prepping it for the swap. Once the LT1 is dropped I can modify my tunnel for the shifter hole as well as put the master cylinder in the firewall. I will also be installing Texas Speed 1-7/8" longtube headers before it goes in! And I'm trying to beat a hard deadline of next friday :icon_slap: so stay tuned because its gonna get intense!
Pedals mounted up and master cylinder hole drilled in firewall.
Texas Speed headers on and looking pretty, along with some fresh NGK plugs and MSD wires.
Lifting the car sky high for one final time to slide the new motor in its final resting spot.
And she's in! So much more room up top than the lt1 and everything is much cleaner looking.
Here is what wiring I have conceptualized after looking at harness diagrams:
This is my first time doing any major harness wiring so feel free to point out any errors or changes that might be present.
I will designate which connector the wire moves from and then to, and free spot means that the pin is blank on the connector.
Move LS1 C101 - Pin C (AIR pump relay control) to LS1 C100 - Pin E
--This will match the air pump wires up to 97 LT1 body, but I deleted the pump
Move LS1 C100 - Pin E (TP Sensor Signal) to LS1 C105 - Pin C (free spot)
--This will match the TP Signal to the LT1 TCS throttle position [is this correct?]
Move LS1 C101 - Pin K (Ignition Retard Signal) to LS1 C105 - Pin A
-- This will match LT1 C105 TCS system spark retard, I deleted TCS though
Move LS1 C105 - Pin G (Engine Speed Signal)[extend] to LS1 C230 - Pin D (free spot)
--This will match to LT1 C230 tach signal to cluster
Move LS1 C220 - Pin A (Oil Pressure Indicator) to LS1 C220 - Pin B [remove grey wire CPP switch that is in B, it is not needed]
--This will match the LT1 oil pressure feed to the cluster
Move LS1 C101 - Pin D (Primary Fuel Pump Relay Control) to LS1 C220 - Pin J
--This will match up to the LT1 Fuel pump relay control
Move LS1 C101 - Pin B (Ignition 1 Voltage) to LS1 C100 - Pin F (free spot)
--This will take power from the LT1 actuators fuse #2 [15amp] and supply power to the ignition
This is what I have so far, I will update as i figure out more wiring. Hopefully everything is correct so far
