LS2 swap 01 camaro
Old Oct 12, 2015 | 12:35 PM
N8427SS's Avatar
Default LS2 swap 01 camaro
So i have and 01 LS1 camaro and i want to swap it to an LS2.
My question is do i need to get an ecu, and harness from a GTO to make the conversion work or will the LS1 harness and ecu work with the LS2.
the LS1 is already built and has been for a while and im just kinda looking to do something different with the car now.... any other suggestions are welcome...
thanks
Old Oct 13, 2015 | 04:15 AM
BODUKE's Avatar
thanks
Your ls1 computer will work with the ls2.
Old Oct 13, 2015 | 08:13 AM
1964SS's Avatar
If your LS2 is 2005 or under it will have 24x reluctor and will work. If it's 2006 it may have the 58x which will have to be changed out.
Old Oct 13, 2015 | 08:17 AM
N8427SS's Avatar
Do I need to get a different harness or will the ls1 harness work I've heard the the cam and knock sensors are in a different location on the ls2 compared to the ls1
Old Oct 13, 2015 | 10:41 AM
tfi racing's Avatar
What are you hoping to gain?Why not just swap the heads/cam/intake,tune it and call it good?
Old Oct 13, 2015 | 12:06 PM
N8427SS's Avatar
I don't have a specific gain that I'm trying to achieve I'm just looking to do something different with the car now other than an ls1..... ive already upgraded the valve train with an ms3 cam and yella terra roller rockers and chromoly pushrods and a 92mm intake with a tune....... I'm more or less just looking to build an ls2 from the ground up I already have the block I'm not sure of the things I need to make the engine work with the wiring and computer I already have
Old Oct 13, 2015 | 12:36 PM
1964SS's Avatar
Here's some info.
http://www.ls2.com/forums/showthread...-in-an-LS1-car
Old Oct 13, 2015 | 04:36 PM
TipsyMcStagger's Avatar
  1. 2005 Corvette LS2 has 24x
  2. 2006 Corvette LS2 has 58x
  3. 2006-2007 CTSV LS2 has 58x
  4. 2006 Trailblazer SS LS2 has 24x
  5. 2007-2009 Trailblazer SS LS2 has 58x
  6. 2005-2006 SSR has LS2 24x
  7. 2005-2006 GTO has 24x
Old Oct 14, 2015 | 04:32 PM
sierravmax's Avatar
Edited ctsv
