LQ4 value
Old Oct 12, 2015 | 09:05 PM
dell72's Avatar
Default LQ4 value
I found an 06 G20 van with an LQ4 6.0 in it. The salvage yard selling it said it might have a "hammered rod" and is asking $200.00, is this a fair price for a core engine that might need a rod/crank repair. Or do I just spend the $1500-$2000 for a running engine from a salvage yard.
Old Oct 12, 2015 | 10:45 PM
LLLosingit's Avatar
Depends on what you plan to do with it. Myself I would buy it, The block alone is worth $200. A hammered rod will likely end up being a complete rebuild with new or replacement crank and rods at minimum.
Old Oct 13, 2015 | 01:01 PM
1964SS's Avatar
I wouldn't buy it if your just looking for a stock LQ4. They are expensive to build. You would probably spend more building it then buying a used running motor.
Old Oct 13, 2015 | 02:38 PM
speedtigger's Avatar
Old School Heavy
$200 for an LQ4 block would be a GREAT price around here if it is undamaged.
