Intermittent Misfire
My tuner told me it was #7 doing it. So far this is what I have checked:
All wiring connections to the PCM, Injectors, coils, 02 sensors, crank sensor, cam sensor, everything good there.
A new PCM, coils, injectors, wires, plugs, cam sensor has been installed and the issue is still there. No vacuum leaks. TPS is reading fine. The harness has a good ground. The heads were checked, springs good, no bent valves, correct pushrod length, good compression.
I am at kind of a loss right now. Any help would be great. The only thing I havent changed were the 02's. But the truck will misfire the same way weather they are turned on or off. It was also tuned MAF only and speed density.
Edit:I looked up the relearn process. A buddy has the snap on scan tool and I'll see if it can do it.
Intermittent fuel problems don't always throw a code, or if they do it can be misleading.
