Please Help!!! Any input is apretiated
Old Oct 25, 2015 | 05:47 PM
Troy Fassler's Avatar
Default Please Help!!! Any input is apretiated
I am building a 69 camaro ls1/t56 , all aluminum f body block, texas speed flat tops and torquer 4 cam, car runs perfect the only problem it has is a small popping noise from the passenger side exhaust (true duals) i will try to attach a video, it only does it while idling, i have swapped coils/wires/plugs with no change, even pulled wires while it was running with no change, it has 90 psi fuel pressure which i will drop the tank and figure out tomorrow (has a vette fpr) and i know that is a problem but not sure if it would cause this. I am open to any advice i'm thinking maybe a bad injector or maybe the excessive fuel pressure?
Old Oct 25, 2015 | 06:52 PM
1989GTA's Avatar
Do you have any exhaust leaks from the head to maybe 2 feet past the O2 sensor?
Old Oct 25, 2015 | 07:59 PM
Old Oct 25, 2015 | 08:01 PM
I have checked for leaks, i even ran it open header and it still does it, it almost sounds like a "knock" in the video but in person it is a "poping" sound coming out of the pipe, i was thinking maybe unbernt fuel in the exhaust igniting?
Old Oct 25, 2015 | 08:03 PM
the smoke you see is from the exhaust being new this was one of the first times i started it
Old Oct 27, 2015 | 06:34 AM
Pop N Wood's Avatar
If it were an ignition misfire I would think the computer should log it.
Most likely an exhaust leak. But that is also a pretty stout cam. Who did the tune?
Old Oct 27, 2015 | 08:32 AM
texas speed mail order tune, all texas speed parts were used, if you unplug the coil or injector on #6 it pops louder, it does not make sense, could a bent/sticking valve cause this?
