speedo conversion
Old Dec 3, 2015 | 10:04 PM
firedan's Avatar
Default speedo conversion
hello all I am new to this great site and I have been searching and cant find a inexpensive conversion from vss to mech speedo. gave 89 chevy truck and want to keep original speedo but don't want to spend 300 or a whole lot more that I have seen to do this. any info please.
Old Dec 4, 2015 | 12:25 AM
LsTaylor's Avatar
I think any electronic to mechanical conversion will be pricey, I've seen kits for the t56 for around $150 on eBay
Old Dec 4, 2015 | 05:41 AM
alocker's Avatar
There is no cheap way to do it. I had to bite the bullet and went with the Dakota Digital driver box at around $300.00.
Old Dec 4, 2015 | 07:15 AM
Pop N Wood's Avatar
Sometimes you can get a new tailshaft for your trans that has the mechanical output. Also both the T56 and TKO sell aftermarket versions with both mechanical and VSS output.
http://www.jagsthatrun.com/4L60_Order.html
Neither option is cheap either.
Unfortunately Cheapest option is going to be electronic speedo.
If like me and you really want to keep the stock speedo you can try taking the guts out of an electronic unit and put it inside your stocker. Not an easy or again cheap option.
Old Dec 4, 2015 | 03:01 PM
firedan's Avatar
thanks guys that's what im looking into replacing guts with newer electric
