Aeromotive Stealth 18688 setup?
https://ls1tech.com/forums/conversio...nsidering.html
I would prefer to use my stock tank and sending unit over replacing it.
thanks, rich.
The only thing I'll tell you is to completely empty your tank and spend plenty of time cleaning out the metal bits once you're done.
thanks, rich.
So, I installed this and am very happy with it. I've run the tank well below 1/4 and have hammered the car pretty hard both in corners and a straight line and have yet to have a starvation issue. Installation was pretty straightforward. This post sucks without pics. I'm going to see if I have any and I'll update this thread if I do. I should update the other one as well.
-Jeff
I did need to cut a hole in my trunk and make a raised cover plate to clear it.....I guess that's the only major drawback to this system in a stock tank. You could probably space the tank down to solve this problem too, but I didn't want to do that.
