Harness Questions
Old Dec 11, 2015 | 09:36 PM
JonQdiesel's Avatar
Default Harness Questions
almost done wrapping up my harness install I am running into this problem. The harness apparently has a 5 wire setup for the MAF sensor. I have a 3 wire MAF sensor from an LS1 that I am going to be adding. I am missing a connector to a sensor on the throttle body. Its a 3 prong sensor and I have no idea what it is. I was thinking that its the IAT sensor with a weird plug. This sensor has 3 wires going to it. How can I take a 5 wire MAF to a 3 Wire maf / 3 wire IAT? IF this is an IAT. I have no more connectors left on my harness other than the 2 O2 Sensor plugs.
Sensor Location Pic
image ru
20mb image hosting
Pulled this off a different harness that I have. Seems to be correct fitment but its 3 wire. Most IAT I ever see have 2 wires.
pic upload
Pic of what I believe is the current MAF connection on the harness at the moment.
post a picture
I have all of my power wires bulked into 3 switched ignition wires. Injectors / Coils Left Bank. Injectors / Coils Right Bank and MAF / O2sensor on another fuse.
Does this seem correct. Just trying to get myself in the right direction.
photo sharing websites
Old Dec 11, 2015 | 10:38 PM
EFIHARNESS's Avatar
the 3 pin sensor in the first 2 picts is tps. The same connector is used for pressure in some apps. the 5 wire maf has air temp built into it.Steve
